Is it possible to to auto increment a data field in a CAN-message during perodically sending?
Here's my problem:
I've to send a can message periodically and auto increment a 16-bit counter on position of byte 3+4 inside this CAN message.
Can I do this with the periodically sending mechanism provided by LabVIEW or have I program this feature on my own, e.g. in an own thread?
(4,145 Views)
Until now, I have developped all my applications with the CAN Frame API vis. As far as I know, it is not possible to do that with these vis.
But a quick overview of the new CAN Channel API vis gives new hope to solve this problem !
From the help for several vis (CAN Init Start, Create message...) :
Output Recent
Output channel data to CAN messages for transmit. This mode is used with sample rate greater than zero (periodic transmit). Use CAN Write.vi to provide a single sample per channel. Each periodic message uses the sample values from the most recent CAN Write.vi.
Unfortunately I have no time to test this right now and therefore I can only hope that this answer will lead you to a solution.
(4,145 Views)
Yes, you can do this by using the frame api or the channel api. With the frame you can use the write periodically feature inside a while loopfor updating the counter values.
With channel api it is much more comfortable because you can do the scaling within max .
Both api´s have examples to get a quick start solution.
(4,145 Views)
Yes, you are right ! I didn't know that it is possible to transmit periodically a non constant message with the Frame API. Thank you very much !
For Roland : see ..\LabVIEW 7.0\examples\nican\Frame - Basic.llb\CAN Transmit - periodic.vi
(4,145 Views)
Great! Many thanks for your responses!
(4,145 Views)
