Is it possible to use a GE fanuc Series 90 (30 or 70) Ethernet-driver for communicating with a GE Fanuc Versamax PLC?
We have installed: Versamax PLC (CPU E05)
LabView 6.1 , DSC and Lookout Protocol Drivers 4.5
We want to communicate the PLC with LabView using OPC. There is not a defined driver for this PLC and we have tried to use GE Fanuc Series 90 (30 or 70) Ethernet-driver without success. What we can do?
(4,323 Views)
National Instruments has released the GE Fanuc Versamax driver with Lookout 5.0. But this is not (yet )in the Lookout Protocol Drivers. You might contact National Instruments to figure out, if there could be a workaround to give you the vmax.cbx.
Hope this helps
Roland
(4,321 Views)
