Is the Editing Database with IO Control example broken?
I was trying the Examples/Hardware Input and Output/CAN/Databases (Editing and Managing)/Editing Database with IO Control.vi code and it keeps returning a Bad reference error when trying to create new Frames.
Cluster creation works fine. Is this just me or the example is broken?
All I did was changing the database name and path in Add Objects/Cluster/New Database, added the cluster and then in Add Objects/Frame I selected the database and tried to add a frame.
If I press the Add Item Now button again, it says the frame already exists:
But if I open the database with Database Editor, the cluster is empty.
I'm using LabVIEW 2017 and NI-XNET 20.5.1.
Kindest regards,
Néstor
LabVIEW 2022 + DIAdem 2020 + Windows 11
(1,665 Views)
Accepted by topic author JoePerkins
If you add a second Cluster to the existing database, then the cluster selector shows actual cluster options and it works.
Or you can add manually the cluster name to the control.
Kindest regards,
Néstor
(1,658 Views)
