LIN Frame Output
I am trying to output LIN communications to an actuator from a vehicle using and NI 9866. We currently have one piece of equipment which is able to drive these actuators via LIN comm (this is not NI equipment). I have used the bus monitor from MAX to monitor the data that this outputs onto the bus. I know that the ID of the actuator that I am trying to drive is 2. This appears in the bus monitor along with the data. I then try to use the example in LabVIEW (LIN frame output single point) to try and output this data onto the LIN bus but nothing happens. The actuator does not drive. I have attached 3 screen shots of what I am trying to do.
Can someone take a look at these screenshots and offer some suggestions? One thing I am not sure of is the frame list selection in the LIN Frame Output Single Point.vi.
ThankYou
Rhys
(7,363 Views)
Here are the attachments
(7,355 Views)
Dear Rhys,
 Could you point me in the direction of documentation for the actuator you are trying to drive, to ensure you are using the correct LIN commands and communication?
Kind Regards,
Sinead B.
(7,286 Views)
Is it possible to PM you the data sheet as it is confidential company documentation?
Rhys
(7,271 Views)
Hi Rhys,
You could upload it to our FTP server using a password protected zip ftp://ftp.ni.com/incoming/  and post the password here. Then it will be possible download it internally download it here at National Instruments.
Kind Regards,
Sinead B.
(7,264 Views)
