LIN comunication "Get start"
Hi
I'm new and this is my frist message. As well i'm new to use LIN. I have NI 9866.
My system is extremly easy: NI 9866 (external supplied by a power supply) with 10V and only one slave.
I didn't find an example only to send a LIN message, in my case an array of 3 bytes .
have you an easy example to do it?
Thanks in advance
Fausto
(5,846 Views)
This forum is for asking for VI's to be converted from one version to another.
You have a regular LabVIEW question you need to ask here. LabVIEW
Be sure to read these links located at the top of the LabVIEW forum.
New to the Discussion Forums?
Please abide by the NI Community User Guidelines and get a quick intro. You can find even more information here!
(5,832 Views)
I have never used LIN.  But if you go to the example finder in LabVIEW and search for LIN you will get many examples for masters and slaves.  Help -> Find Examples
(5,804 Views)
Hello FaustoTromba,
are you working with ADCS or XNET ?
Check and Test the Examples (Help->Find Examples ->Hardware Input and Output -> LIN) and if you have a problem you can ask for help.
Regards
(5,570 Views)
