LIN termination
I use LIN with UDS with the Automotive Diagnostic Command Set.
After opening the diagnostics with "Open Diagnostic on LIN.vi", I call the "Diag Set Property.vi" with the property ID 15 (=Termination) and value 1. As soon as I write this property, independent of the value 1 or 0, I can't see any activity on the LIN. If I don't call this, the communication on LIN is working, but the termination is missing. If I connect an external termination, it is OK. But if there is this option, to connect the internal termination, it also should work...
Any idea?
Madottati
(5,232 Views)
Hey Madottati,
What is UDS?
Which hardware do you use?
Which driver/LabVIEW Version?
Could you please also post the VI, which you use?
Stephan
(5,194 Views)
