LIN transmit frame complete
I want to send a frame once as a LIN master with a NI 9866. I want to wait until the frame is transmitted. I tried the XNET Wait (transmit complete).vi, but it throws an error -1074384753:
NI-XNET:  (Hex 0xBFF6308F) The function you called is not defined for the session mode (e.g. you called a frame I/O function on a signal I/O session).
How to synchronize to the end of transmit?
(4,351 Views)
Accepted by topic author Madottati
I think you can just change your session type from single point to queued.
(4,327 Views)
