[LV 8.5] CAN bus: How to enable/disable the transmission of a frame ?
I use the CAN Transmit-periodic.vi in LV 8.5, I want to enable or disable the transmission of a frame without stop the loop of my VI, does it exist in the frame api a vi which could stop, or mask the transmission of a frame?
It's important I don't want to stop my VI that send my frame just filter a frame that I don't want send on my CAN bus...(I would command it with a boolean for example).
Thank you.
Bye.
Message 1 of 1
(6,587 Views)
