Labview ECU MC Examples Running Error(error-301096)
Hello All, I'm running  the example "Edit a parameter curve.vi" always appear "Error-301096" without a real ECU, Error: A timeout occurred while waiting for a response from a slave device.
  • My hardware communication tool is "USB-8501".
  • My Labview software version is "LabVIEW Runtime 2018 SP1 f5".
  • My ECU MC Toolkit version is "ECU Measurement and Calibration Toolkit 20.6", also installed "ECU Measurement and Calibration Toolkit Runtime 20.6".
  • My NI-XNET version is "NI-XNET 20.5.1"
Before each time run the "Edit a parameter curve.vi", I've already run the "ECUMC Demo ECU XCP.vi", The following picture is detail configuration:
It's only display ECU Running, Then I running the  "Edit a parameter curve.vi", The following keeps happening:
I use "ECUMC XCP and CCP Trace" monitoring  the communication Frame information,  It is observed that only have request frame without response frame, the following picture is detail:
I am troubled by this question,  I appreciate being offered some solutions to the problem.
Thanks!
ALian
New User
Message 1 of 8
(7,283 Views)
Accepted by topic author 阿莲
     Problem solved.
The ECU MC Examples Running simulation need config Protocol: TCP/IP, Not Protocol: CAN ,               Follow the link below:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGumCAG&l=zh-CN
ALian
New User
Message 2 of 8
(7,258 Views)
Can i run Ni Xnet frame transmissions and ECUM simultaneously.
Message 3 of 8
(5,963 Views)
Please start a new thread for a new question.
Anyway, see Run ECU MC or ADCS and XNET Simultaneously On the Same CAN Port
https://tmesystems.net/
Message 4 of 8
(5,959 Views)
I have tried it, and it's giving an Error. Please share any solution.
Message 5 of 8
(5,950 Views)
The baud rate settings must be the same.
What are the baud rate settings on DBC and A2L files?
Message 6 of 8
(5,942 Views)
Baud Rate the same as 500k If run parallel ECUMC and xnet it s gives error
Message 7 of 8
(5,929 Views)
The ECUMC Demo ECU XCP runs on CAN 2.0, but your DBC is running CAN FD+BRS.
Message 8 of 8
(5,911 Views)
