Laptop/Desktop configuration for High Speed CAN USB NI USB-8473
Hi, We are evaluating NI USB 8473 for one of the upcoming project. My requirement is as follows. 1. The NI USB 8473 will be connected to a Laptop which will emulate more than one CAN Nodes and communicate with Other System. The system on other side would be built on a real time platform. 2. I will send different parameters at different update intervals over the CAN using CAN Open. 3. I need my application to support sustained bus load of 100% at 1 Mb/s over CAN (CAN Open) and test and prove that it works as specified. I would like to know the following: 1. Whether (NI USB 8473) would be a suitable selection for the requirement that I have mentioned above. 2. What would be the suitable Laptop configuration for me to get speed up to 1 Mb/s. (In terms of CPU, USB port, RAM, Operating System, Bus Speed etc...Lets assume we use NI Labview built application on the Laptop). 3. The PC / Laptop CPU Loading for this to run. - TCP
(8,510 Views)
I use the USB-8473 to simulate (and log all CAN bus data) as many 15 ECUs (J1939 at 250 Kbps), but regarding CPU usage, it depends on how you write your code.  A modem low-grade dual-core computer can easily handle a 100% loaded 1Mbps CAN bus, but it depends on your code...polling in a tight loop w/o any delay will waste CPU time, and what you do with the data (i.e. screen updates) will affect CPU usage.
I have experienced problems with all NI high-speed non-XNET CAN devices in regards to reliably sending out data for an extended period of time.  With my simulations (and a simplified version I sent NI), the CAN messages would run w/o problems for only for a few hours, then stop sending messages for no reason at all (no error codes).  I worked around the bug by detecting when the transmit buffer would fill-up, at which point I would reset the card.  NI was able to duplicate this but as far as I know, has not fixed the issue.
If you must use NI, it would be best to use an XNET card unless you can work around this NI-CAN problem.
BTW, NI CAN devices are only supported under Windows, and if CAN bus-off happens, you have to recover from the error yourself (other devices, even $5 PIC micros do this automatically).
I hope this helps,
Todd
(8,505 Views)
Thanks Todd for sharing your experience.
I need to have my interface that suits Laptops and Desktops.
May be XNET will have to sit on the PCI / PXI.
I am also asking NI if they have closed such open issues in their subsequent releases.
cheers,
TCP
(8,498 Views)
If you open CAN port and handle references via loop Registers you shouldn't have any problem with USB-8473.
I run my code for weeks without any problems. "ref in -> ref. out"
(7,410 Views)
Note, it is a violation of the spec to have the interface automatically recover from CAN bus-off.
Per ISO 11898,
section 4.14 "bus off"
A nodes is in the state "bus off" when it is switched off from the bus due to a request of fault confinement entity. In the "bus off" state, a node can neither send nor receive any frams. A node can leave the "bus off" state only upon a user request.
(7,406 Views)
