MAX does not show scanner card
I'm using an Allen-Bradley 1784-PCDIS PCI scanner card, and it does not show up in MAX. I've un-installed the card, un-installed NI-DNET 1.41, then re-installed NI-DNET, installed the scanner card, and it still doesn't show up. The card does communicate if I use A-B's RSNetworx or IOLinx, but if I try any LabView VI's, I have no luck. Any ideas or suggestions?
I'm running Windows XP Professional with LabView 6.1.
Additional note - the same PC has a NetMos dual RS-232 card installed, which also doesn't show up in MAX, but it works perfectly with any VI that I test it with.
(3,527 Views)
Hi knorcross
The NI-DNET software supports only National Instruments DNET (and with restrictions CAN) hardware products. DeviceNet products from other vendors are not supported (and thus, they won't show up in MAX). For information or device driver software, please refer to the documentation you received with your Allen-Bradley 1784-PCIDS scanner card.
-B2k
(3,522 Views)
