More information on the 188791-01 PCMCIA-CAN Synchronization Cable?
Datasheets for the PCMCIA CAN interfaces indicate that this cable can be used for synchronizing with DAQ channels.
What kind of channels?  It is clear from what I've read that PXI CAN synchs with PXI DAQ in the backplane, and that on the PCI platform DAQ and CAN are synched via a RTSI cable.
Can I use this PCMCIA cable to somehow synch with a USB-9233?  To which DAQ devices can I synch PCMCIA-CAN?
Thanks In Advance - MJD
Mike Dillon
Product Manager - Sound & Vibration Software
MTS Systems Corporation
(3,862 Views)
Hi Mike,
With the mentioned synchronization cable, the PCMCIA-CAN cards are able to use four general purpose (digital) trigger lines as well as import a 10 MHz clock from any external source (e.g. to synchronize the timestamping of CAN frames to the external device).
The NI USB-9233 does not provide any kind of external access to its internal trigger/clock signals. Thus, the only way so provide some sort of hardware synchronization would be to let the PCMCIA-CAN card generate periodic (toggle) pulses (i.e. use the provided 10 Hz Resync pulse) on one of its trigger lines and receive that signal with one of the four inputs of the NI USB-9233. As the period of that pulse is known, one can correlate the sampled DAQ data with the timestamps of received CAN data and keep drift to a minimum.
As the NI USB-9233 cannot output any signals it cannot provide an event the PCMCIA-CAN card can react on.
While this is certainly not an elegant solution, there are better ways to synchronize the PCMCIA-CAN cards with DAQ devices.
The easiest way to synchronize the PCMCIA-CAN card with a DAQ device is, when the DAQ device is able to export a 10 MHz clock signal (for clock synchronization) as well as dedicated start trigger signals. This applies to the PCMCIA DAQcards (Analog Output or Multifunction DAQ) or the USB NI DAQPads (6015, 6016 and 6020E).
However, none of the above mentioned DAQ devices is a DSA device and does not provide true simultaneous sampling or 24 bit of resolution.
For more information on the synchronization capabilities, please take a look at the PCMCIA-CAN section of Chapter 3, NI CAN Hardware of the NI-CAN Hardware and Software Manual (in particular pages 3-24 to 3-26).
-B2k
(3,855 Views)
B2k -
Thanks for both of your responses.  I'll do some more research from here.
- MJD
(3,852 Views)
