Motor current and valve current control using same CAN interface.
HI,
I want to control motor and valve currents for certain time. The controling currents for valves and motor are different for diffrent time, they also have different repetation time for test.
My problem is how could i operate all the valve and motor at the same time.
I am  using NI-X-net, i ahve attached a capture, the controlling of valves and motor signals are in the same message PSD1- x605.
The valve are motor operation is also attached in xlx file.
Thanks.
Rahul.
(4,013 Views)
Accepted by topic author Rahul1189
please suggest me that how can i Run motor and valves seprately, at a ame time, i have attaced a program, in which i am running motor and valves together, but i want to run them with different repetation time and control the current for valve and motor with respect to time, diffrently.
Thanks in Advance.
(3,991 Views)
