Mulitple CAN Msg transmission(s) from Flexlogger to ECU
Using flexlogger to Monitor the CAN bus and transmit the CAN MSGs (from flex logger) to ECU. Able to perform this manually for 10 MSGs.
However, there is a situation got to transmit 8192 CAN frames(8-byte payload) periodically(say every 10msec) to ECU. These frames have the same ArbitrationID but the payload (8-bytes) data will different for every frame and every byte as well.
Is there any option to have the frames created in Excel/csv in a format and import in the flexlogger to transmit the big number of messages.
Very new to the Tool chain., let me know if any additional questions.
Greatly appreciate the support!
Message 1 of 1
(1,470 Views)
