NI 9862 comes us as unsupported module in MAX
Understood.  Thanks for clarifying.
Message 21 of 33
(6,942 Views)
I have had similar behaviour on 3 separate cdaq systems (rubbing a mix of xp and win7).
When updating divers with disk that shipped with lv14 any 9862 can devices appear as unsupported devices.
Manually updating the drivers through control panel and device manager, selecting the device allows the 9862/hs device to be selected and the can module then works fine.
Despite having the cdaq chassis connected (with can module installed) during the update the new install option for xnet cdaq support has to be manually selected, which is OK if you know about it...
Probably the poorest driver update experience I've had in 12 years of doing them.
Message 22 of 33
(6,585 Views)
I had the ploblem and I solved it.
If you still have problem let it know here I will help you.
Message 23 of 33
(4,354 Views)
I have same problem and then need solve method
please reply to  me, I want to your help
OS is windows 10 homepack
Message 24 of 33
(3,997 Views)
Your computer is 32bits or 64bits?
Jerome
Message 25 of 33
(3,992 Views)
For me, my problem was on XP SP3 32bits comuter.
In the device manager the board was with a yellow triangle...
A section is missing  in a nixntcdq.inf file to install the driver on X86 machin.
I send you the folder in a zip. Go in the device manager and click on update driver then select this folder.
Try and let me know the result..
Jerome
Message 26 of 33
(3,990 Views)
thank you for reply
my computer is 64bits.
Message 27 of 33
(3,991 Views)
Just an idea: You have installed XNET drivers?
Message 28 of 33
(3,986 Views)
Hi.
I installed NI-XNET 16.1 driver and NI DAQmx Device Driver 16.0.1.
Message 29 of 33
(3,972 Views)
Have you tried going into windows device manager and manually assigning the XNET driver to the "unsupported device"? Which steps of this forum post have you tried to no avail?
Message 30 of 33
(3,924 Views)
