NI CAN Device Simulator
Have couple of questions about the NI CAN Device Simulator:
1.  Does this Simulator work without the NI-CAN interface cards?  I.e., can I use it as one of the CAN devices on the bus?
2.  Does it support the SAE-J1939 standard?
Thank you in advance!
-Khalid Ansari
Message 1 of 8
(7,058 Views)
Hi Khalid,
To answer your questions:
1. The NI CAN Device Simulator works without NI-CAN interface cards. However, the examples dicussed in the NI CAN Demo Box User Guide require NI-CAN (and thus NI-CAN hardware) and LabVIEW.
2. The NI CAN Device Simulator uses only the standard 11-bit arbitration IDs (formerly known as CAN 2.0 A) whereas the SAE J1939 protocol uses the ‘extended’ 29-bit arbitration (formerly known as CAN 2.0 B). As the arbitration IDs cannot be reprogrammed you can use the device simulator in a J1939 network, it would not be a real J1939 device, however.
-B2k
Message 2 of 8
(7,051 Views)
Hi B2k,
Thanks for the prompt response!
So if I understood you correctly, since the Simulator supports only 11-bit Arbitration IDs, it will be outputting data frames with only 11-bit IDs, right?.
-Khalid
Message 3 of 8
(7,045 Views)
Yes, it only outputs 11 bit frames, and at a very slow baud rate, slower than you need. It is mainly used as a training aid for CAN with Labview.  You need 29 bit ID's with 250K baud.
Check your GMAIL, I sent you a message about what you are looking for.
Message 4 of 8
(7,041 Views)
Thank you!  Appreciate your help.
-Khalid
Message 5 of 8
(7,031 Views)
Related Subject
I'm looking to do some ATE and maybe HIL using LabView. J1939 will be a large part of this, is it possible to use another CAN hardware supplier for this since 29bit identifiers are not used?
Message 6 of 8
(6,734 Views)
I just want to clarify that our CAN interface boards do support J1939.  It is only our CAN Device Simulator that doesn't support J1939.
Message 7 of 8
(6,719 Views)
Oh ok I see. All clear, thanks mike!
Message 8 of 8
(6,713 Views)
