NI-CAN Error (hex 0xBFF620002) detected by NI-MAX when opening the bus monitor interface of the USB 8473
when opening the bus monitor interface of the NI-MAX related to the device USB8473 several time I get  the message:
- File could not be created
and then the error message:
- NI-CAN Error (hex 0xBFF620002).
Below the system characteristics:
- System: WIN 7
- NI-MAX: 14.5
- NICAN: 14.0
Attached the error file.
Thank for your help!
Alessandro Serafini
th
(2,670 Views)
Hi Alessandro,
first of all I apologize for the late reply. I don't know if in the meantime you managed to solve the issue in some way, otherwise the only thing I can advise you to do based on the little information provided is to try to uninstall and reinstall the NI-CAN drivers.
Alessia
(2,545 Views)
