NI-CAN compatibility
I have a PXI rack with a NI PXI-8513 CAN/XS card. I want to use it in NI-CAN compatible mode because my test program and all other systems uses this card. How do I install the compatibility mode? The rack has been supplied without the setup disks.
(6,478 Views)
Hi Philhan,
The CAN compatibility library for your card is included in the NI-XNET driver package, which can be downloaded from here.
When installing the driver, make sure you install the "NI-XNET Compatibility for NI-CAN" feature.
Jas.W
Jason W.
National Instruments UK & Ireland
(6,462 Views)
