NI-CAN driver for XP-64
I need to run NI-CAN on Windows XP 64-bit OS.  I want to use NI USB-8473 on my workstation but the driver CD that came with this hardware says its not supported.  Is there a workaround or will NI-CAN support XP 64 in the future?  If the latter, is there a beta version out there I can use?
Jim
(5,974 Views)
Jim,
Thanks for the post.  Unfortunately, there is no way to run NI-CAN on XP 64 bit.  There will not be support on XP-64 either;  for 64-bit OS support you'll need to use wither Windows Vista or Windows 7.  Unfortunately, there is not a beta version of the driver either.  I apologize for the inconvenience.
Jon S
(5,957 Views)
