NI-CAN port to port example on RT target
I am attempting to use a NI PXI-8461/2 Series 2 card in my NI PXI-1045 real-time controller. I am using the 'Single Sample Periodic Output' and 'Single Sample Input' VIs. I am getting an error: "The interface is transmitting frames, but no device is receiving". The version of NI-CAN on my computer and the RT target is 2.6.2. Both ports have been set to the same speed in MAX, and the channels have been setup correctly. I have connected both ports using a female-to-female DB9 serial cable (2 m long). Is this the right type of cable? The ports are currently on highspeed, I can't figure out how to set them to low in the MAX configuration window (it does not allow editing). Thanks
(6,544 Views)
Accepted by topic author adamea
Problem solved.
It was the cable - it must've been a crossover cable.
(6,540 Views)
