NI-CAN simultaneous Read/Write at different sample rates
Hello everybody,
I am a beginner in LabVIEW and here is my problem :
I would like to read a CAN message every 10ms, and then write a CAN message (with the data received from the CAN Read.vi) every 20ms.
Do I have to build 2 different While loops to do it ? If it's right, how can I share the data between the 2 loops, without losing any value ? With queues ???
I have already made a VI that read and write at the same sample rate (i.e. 100 Hz => 10 ms). But when I put 50 Hz in the Task Init Start function for the CAN Write function, I'm losing values (I have only 1 While loop).
If you have any exemple of functions doing nearly the same, I am interessed in.
Thanks in advance !
(5,838 Views)
Same post has been posted in the French section.
Please refer to it for more information :
http://forums.ni.com/ni/board/message?board.id=4170&message.id=19294
Alexandre - NIF
AE
Alexandre M. | Certified LabVIEW Developer
Embedded and Control Systems Engineer (NI France)
(5,807 Views)
