NI PCI-CAN/XS2 with HP computer.
I have tried connect a NI PCI-CAN/XS2 into a HP computer (AThlon 64) and it is not recognized. This same board is recognized easily in another computer (DELL, INTEL).
 Could is there a issue with HP Computer ?
I have the same issue with a  NI DAQ board 6509.
Thanks a lot.
Nelson Sartori Junior
Test Engineer Magneti Marelli Brazil
(5,460 Views)
Olá Nelson,
Qual o sistema operacional você está utilizando no computador que não reconhece as placas? No seu post, você disse ser um Athlon 64 bits, e infelizmente ainda não temos drivers desenvolvidos para plataformas 64 bits. Caso você esteja utilizando um computador 64 bits com um sistema operacional 32-bits, as placas devem funcionar adequadamente.
Which operating system are you using in the computer that doesn't recognize the boards? In your post, you said that it's a Athlon 64 bits, but unfortunately we don't have drivers to 64 bits PCs yet. if you are using a 64 bits computer with a 32 bits OS, the boards might operate without problems.
Alisson Kokot
NI BRAZIL
(5,453 Views)
Oi Alisson,
Nosso time de TI conseguiu resolver o problema ,baixando do site da NI a versão mais nova da DAQ (8.6) e da CAN (2.5). Eu estava usando a versão que veio com as placas (DAQ 7.4 e CAN 2.3.2). Mas essa problema dava tanto com Windows2000 pro quanto XP.
Our IT team have solved this issue, downloading the latest versio of DAQ (8.5) and CAN (2.5). This issue has occured with WIN200 pro and XP.
Thanks a lot and best regards.
(5,429 Views)
