NI X-NET error
I am trying to set default value for a signal using property node, but I always get error "1074384561". 'NI-XNET: (Hex 0xBFF6314F) Database object is locked because it is used in a session. Solution: Configure the database before using it in a session'. The irony is that I have not opened any session/s.
Can Someone point out, where went wrong
(1,688 Views)
Would you provide a VI demonstrating this?
(1,667 Views)
