Need help with INCA software for flashing binary to ECUs
Hello
Anyone worked on INCA tools for flashing the ECU please ?
I use the INCA tools for the first time . I would like to cset a prof config to flash binary file to my ECU . I tried to create the needed files . I have some question please .
1/ to convert the hex file into binary file i copied this from tuto
[convert_bin]
RUN_DLL ("CONVERT.DLL",convert,-h,-i,-q,-b,%1)
case TRUE : $return TRUE
default : $return FALSE
[convert_bin_END]
I would like to know what is the CONVERT.dll file it will be generated or should i create this file ?
2/ Can I flash directly a binary file to my ECU ?
3/ who can correct my script I have several problems on ?
thanks a lot
Message 1 of 1
(2,387 Views)
