.Net wrapper for XNET API.
Dear Sir,
I try to program   XNET (CAN & LIN) with C#.
I found the example for the ANSI-C.
I try to conver this example to C#, but it's very difficult to me.
Some body already have .Net Wrapper for XNET API? and can share ?
Hiawath
(8,013 Views)
Hi Hiawath,
There's currently no support for our customers willing to use XNET with a .NET programming language. As per the example in C and the use of P/Invoke, you can create a C# wrapper for your needs, yet we cannot really assist you in doing this.
A useful document to get started:
- http://www.codeproject.com/Articles/403285/P-Invoke-Tutorial-Basics-Part
You can also share you experience with your local sales representative in case he can figure out a better way out for you.
--Eric
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(7,972 Views)
Dear Sir,
I try to wrapper for the "nixnet.dll" and worked very well for the "nxCreateSession" and "nxWriteSignalSinglePoint".
But I can't get the data from " nxReadSignalSinglePoint" , even though compile OK,
Can you see  "nxReadSignalSinglePoint" and advice ?
Andrew.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Runtime.InteropServices;
using System.Threading;
namespace ConsoleApplication2
    class Program
        public const string DLL_NAME = "nixnet.dll";
        static IntPtr g_SessionRef;
        static IntPtr g_SessionRef2;
        [DllImport(DLL_NAME, EntryPoint = "nxCreateSession", CallingConvention = CallingConvention.Cdecl)]
        public static extern Int32 CreateSession(string DatabaseName, string ClusterName, string List, string Interface,
            UInt32 Mode, out IntPtr SessionRef);
        //nxStatus_t _NXFUNC nxCreateSession(
        //                   const char* DatabaseName,
        //                   const char* ClusterName,
        //                   const char* List,
        //                   const char* Interface,
        //                   u32 Mode,
        //                   nxSessionRef_t* SessionRef);
        [DllImport(DLL_NAME, EntryPoint = "nxReadSignalSinglePoint", CallingConvention = CallingConvention.Cdecl)]
        public static extern Int32 ReadSignalSinglePoint(IntPtr SessionRef, out IntPtr ReadValueBuffer,
            UInt32 SizeOfValueBuffer, out IntPtr TimestampBuffer, UInt32 SizeOfTimestampBuffer);
        //nxStatus_t _NXFUNC nxReadSignalSinglePoint (
        //                     nxSessionRef_t SessionRef,
        //                     f64* ValueBuffer,
        //                     u32 SizeOfValueBuffer,
        //                     nxTimestamp_t* TimestampBuffer,
        //                     u32 SizeOfTimestampBuffer);
        [DllImport(DLL_NAME, EntryPoint = "nxWriteSignalSinglePoint", CallingConvention = CallingConvention.Cdecl)]
        public static extern Int32 WriteSignalSinglePoint(IntPtr SessionRef, double[] ValueBuffer, UInt32 SizeOfValueBuffer);
        //nxStatus_t _NXFUNC nxWriteSignalSinglePoint(
        //                           u32 SizeOfValueBuffer);
        static void Main(string[] args)
            string l_pSelectedInterface = "LIN2";
            string l_pSignalArray = "";
            string l_pSignalArray2 = "";
            string l_pSelectedDatabase = "IG";
            string l_pSelectedCluster = "Cluster";
            string l_pSelectedSignal1 = "LH_HeaterSWLEDHigh";
            string l_pSelectedSignal2 = "LH_HeaterSWLEDMid";
            string l_pSelectedSignal5 = "LH_HeaterSWLEDLow";
            string l_pSelectedSignal3 = "LH_HeaterSW";
            int g_Status = 0;
            double[] ValueBuffer = new double[2];
            IntPtr ReadValueBuffer = IntPtr.Zero;
            IntPtr TimestampBuffer = IntPtr.Zero;
            /// for read from LIN
            l_pSignalArray = l_pSelectedSignal1;
            l_pSignalArray += ",";
            l_pSignalArray += l_pSelectedSignal2;
            l_pSignalArray += l_pSelectedSignal5;
            // for writing to LIN
            l_pSignalArray2 = l_pSelectedSignal3;
            l_pSignalArray2 += ",";
            l_pSignalArray2 += l_pSelectedSignal5;
            g_Status = CreateSession(l_pSelectedDatabase, l_pSelectedCluster, l_pSignalArray,
                l_pSelectedInterface, 0, out g_SessionRef);
            g_Status = CreateSession(l_pSelectedDatabase, l_pSelectedCluster, l_pSignalArray2,
                l_pSelectedInterface, 3, out g_SessionRef2);
            ValueBuffer[0] = 0x01;
            ValueBuffer[1] = 0x00;
            // write
            g_Status = WriteSignalSinglePoint(g_SessionRef2, ValueBuffer, 16);
            /////////////////////  read
            g_Status = ReadSignalSinglePoint(g_SessionRef, out ReadValueBuffer, 24, out TimestampBuffer, 24);
            return;
(7,789 Views)
I don't know .NET, but looking at your code, you are marking "ReadValueBuffer" as an 'IntPtr'. This is actually a double-precision floating point value.
 I don't know if this helps.
(7,777 Views)
hummm,, its 2016 and no support for .NET framework? I wonder if NI is pushing customers to competitors for in-vehicle CAN (ValueCAN, Vector CANTech, etc) for not being able to interface to new development environment. Afterall, Measurment Sudio uses WPF.  If I have the hardware; why do I need to shling another $1k for development environement that I can get for free from Microsoft. Its not rocket science; only CAN messages.
(6,751 Views)
Any luck? I am also looking for C# code for LIN2.0.
(5,838 Views)
