NiCan selection of individual read messages using InVehicledatlogger
I need to log selected CAN measurements e.g. veh speed and throttle travel etc. as wel as DAQ data.I am at present using Invehiclelogger.vi. I would appreciate assistance.I have a full development system ver.6.1 and CANDS board plus PCI 6031E DAQ board.
Regards
(3,966 Views)
Hello-
The great thing about NI-CAN and LabVIEW is flexibility. It is possible to do many things with the data once it's received (write to file, print, send over DataSocket). This requires modification of the VI to fit the required need. It will also require knowledge of the data of the CAN bus. This CAN-specific information should be obtained from the manufacturer.
Randy Solomonson
Application Engineer
(3,966 Views)
