Nican.h
Hello
I am developing an application using Visual c++ 6.0 but when i include "nican.h" the compiler gives me an error: cannot open include file nican.h .Why?
(6,225 Views)
There are really only 2 possibilities for this problem. Either nican.h does not have the read attribute set (and you are using NTFS), or the file is not in your path. It is more likely that it is not in your path. You should be able to put the nican.h file in the directory that has all of the code, and do a "#include "nican.h".
Hope this helps out.
Best Regards,
Aaron K.
Application Engineer
(6,225 Views)
Aaron K,
Where can i download NICAN.h?
(6,009 Views)
webb_xie,
The nican.h file comes with the NI-CAN driver and the driver is downloadable using the following link:
NI-CAN Download
The nican.h file installs typically to the ...\National Instruments\NI-CAN\MS Visual C Folder.
DirkW
(5,997 Views)
