OBD II Enhanced PIDs with ADCS
Does the ADCS support retrieving extended/enhanced PIDs via service $22, as-specified in J2190? Or does it only support services $01 - $10 as-specified in J1979?
(5,211 Views)
I've used this toolkit very little, but in searching the manual found here, all I found was references to the J1979 standard, and no mention of the J2190 standard.  I'd look through that manual and see if the functions give you the features you want.  You can also download a the toolkit and use it on a trial basis to evaluate if it has the functions you need.
(5,208 Views)
Accepted by topic author jpeabod6
The manual that Hoovah linked shows it supports ReadDataByIdentifier, which is service $22.  Generally these services are refered to as UDS (ISO 14229), but there is a lot of overlap between all the various specifications.
(5,196 Views)
Thanks! This was exactly what I needed.
(5,178 Views)
