ORing the arbitration ID in a cluster in Write Net Multi
I am using Frame API CAN, and would like to write several messages to my device.  The trouble I am having is my arbitration ID, it needs to be 29 bit instead of 11.  I know that I need to OR it, but how do you go about this when it is in a cluster.  Please feel free to look at my code in the attactchment.  Thanks
Fred
Message 1 of 9
(8,264 Views)
Accepted by topic author wana be prog
You could set the 30th bit manually or use the unbundle function to do it pragmatically. See the modified example for more information.
DirkW
Message 2 of 9
(8,254 Views)
Hmm, I tried the unbundled method and it gave me a wiring error, when I did this before posting the original message.  But I realize what I had done, I had just added a wire going to the unbundle, instead of going to the unbundle, re-bundling and wiring back to the write function!   Thanks, I appreciate your help.  Fred
Message 3 of 9
(8,250 Views)
Hi DirkW!!
I have PXI CAN card 8164  in RT and I try writ with VI frame and I use the VI like this:
But I can't read nothing, with this VI suppose I can Transmit and Receive for the same port but I haven't nothing, You Know Why?
Best Regards
Please Help me!!!!
Message 4 of 9
(7,936 Views)
Hi Kaliman,
Do you receive an error when you try to run this program, or does it just return no information? Also, I can’t find any information on a product 8164, can you double check that number? Thanks,
Matt
Matt
Message 5 of 9
(7,911 Views)
Sorry the Can Card is 8464, and when I run the VI no return Information, and not out error's just run the VI without error that show me and not return information
Message 6 of 9
(7,901 Views)
I am attempting the same function (read/write) using extended ID and 8461 card.
Have you double checked your baud rate? I'm using 250000.
I can read the CAN bus fine; however, I cannot see the data I'm requesting using the write command.
Message 7 of 9
(7,885 Views)
I fixed my vi by setting the Standard Comparator and Extended Comparator to CFFFFFFF on CAN Netwrof Interface Config.
Message 8 of 9
(7,884 Views)
Thanks, Please, you say me that fix you VI in Setting, can you tell me where exactly,
Message 9 of 9
(7,870 Views)
