PB with the labview example "CAN Transmit multiple" doesn't work
I have a problem with the example "Can transmit periodic" I joined it with the post...
I use CAN0 and I put 500 000 for the bauds rate.
I have an error:
"NI-CAN:  (Hex 0xBFF62007) Vous avez essayé de définir un attribut de configuration pendant l'exécution d'un objet. Solutions : configurez les attributs avant l'ouverture de l'objet ; arrêtez et relancez la communication de façon à pouvoir mettre à jour les attributs de configuration."
In english: "I try to define an attribute of configuration during the execution of an object. Solutions: configure the attrubutes before open the object"
Have you the same problem?
(6,237 Views)
have you solve your problem, I see youre other post.
Regards
Yann C.
France
(6,224 Views)
