PCI-CAN HS 2Ports Support
Getting the following msg using a PCI-CAN HS 2 board.
WARNING ncReadMult: Unknown status (3ff6206b)
Trying to track down exacly where and why this msg is generated.
I have tested the card; it's OK. Has been runing for months previously with no problem.
I seem to be able to read directly, with no problems, from M&A (NI) application.
Cables seem OK, but are sealed connections, so no absolute there.
I am accepting all ideas at this point. Help if you are able.
Dave
(7,279 Views)
Accepted by topic author hubd
hubd,
Have you seen these very similar forums.  They both offer some very good suggestions.  So long as it is still a warning it means you lost a frame, when it becomes an error you may have a connection problem.
Sincerely,
Jason Daming
http://www.ni.com/support
(7,267 Views)
Thanks Jason. No I had not seen the other listings. For some reason they did not pop in the search I did.
That actually helps a bunch.
Dave
(7,262 Views)
