PCMCIA CAN/2 und DIADEM
Hello Everyone,
can anyone tell me if the PCMCIA CAN/2 is directly supported by Diadem / Max WITHOUT the use of external drivers (ie Vector db files)?
Thanks, Jeff
(5,343 Views)
Hello Jeff,
the only thing you need is the NI_CAN driver for your device. Then install the driver, put in the device, go to MAX and make a channel list. Start DIAdem, got to DAC module. There you will find a CAN block. in it you can load the CAN channels and work with it.
Hope this helps,
Rebecca Fox
(5,337 Views)
Thanks for the quick reply!
Jeff
(5,330 Views)
