Hello-
After downloading and installing the latest NI-CAN driver from ftp.ni.com/support/ind_comm/CAN, be sure to map the ports to the proper network interface objects. In Windows NT/2000, open Control Panel and use the NI-CAN configuration utility. In Windows 9X/ME, open Device Manager and click on the properties of the desired CAN card to get to the configuration utility. In the configuration utility, click Port1 as CAN0. Then, for two-port boards, select Port2 and click CAN1.
After the board is properly configured, be sure the powering is set properly. For non-PCMCIA cards, there is a jumper label "int" for internal and "ext" for external power. For PCMCIA cards, the type of power is determined at the time of purchase.
Also, some Windows NT system
s use PCMCIA socet services. Our CAN cards usually have problems with these services. It is recommended to use the native Microsoft PCMCIA socet services.
Randy Solomonson
