PCMCIA CAN and MAX Bus Monitor
I have a series 1 PCMCIA CAN Controller Card (184272F-01) and Series 1 CAN Cable (184354B-01) attempt to communicate with a DDC RPC CAN Interface (29bit arbitration ID, 250K Baud)
Command:  Version ID?: 0000 0000 0000 001B
29bit ArbID: 0x18EFE3E1
1-First does MAX actually wrap the remainder of the Full CAN message, for example the CRC checksum?
2-Can I run the Bus Monitor and send out the message with Test Panel at the same time?
thanks in advance,
JS
(5,991 Views)
1. Yes it does.
2. Yes you can.
Have Fun.
DirkW
(5,983 Views)
