PXI-8512 Termination Resistors
Hi NI community,
I have question about the termination resistor on PXI-8512.
As per NI-XNET manual chapter 4, termination of 120 ohm can be enabled/disabled.
The interface board I am having right now does not have the line termination in the design nor does the interface cable.
So I want to make sure that there is an option for termination resistor on PXI-8512.
Thanks in advance
(2,987 Views)
If the manual says it is there then NI is saying it is there.  I believe all XNet CAN hardware has this built in.  This can be enabled or disabled through the XNet API using a Property Node in LabVIEW.
(2,960 Views)
