Problem with Periodically sending CAN frames
Hai Friends.....
i am facing a problem with periodically sending CAN Data frames,,,,few of the CAN Data are reached the end system but few of data are not reached where my data are having different arbitration ID...,my software is running fine about 5 to 6 times without any issue after that some of the CAN messages are not reached the end system....if i restart the PC, it is working fine....,so please help me on this,...what is the reason for this issue....I want to send CAN Data frames periodically with different arbitration ID without restarting the system...,
(7,147 Views)
Hi msarun,
Would it be possible for you to post your code or a screen shot of your code?
Also, you mention that restarting your computer fixes the problem. Does this mean that simply closing and reopening the VI, or restarting LabVIEW does not solve the problem?
Also to clarify, do you only run into problems if you change the arbitration ID?
It would be helpful to post your LabVIEW version and driver versions as well.
Have a great day!
Tanya Visser
LabVIEW Group Manager
(7,128 Views)
Thanks for your response Mr.Tanya,
Please find the attached screenshots. i am using Write CAN Data.vi for sending CAN messages and i am using CAN Close.vi to close the CAN Port at the end(After sending all CAN data).
(7,111 Views)
Hi msarun,
Usually the CAN close would be in the same VI as the Open. Also your write should be in a loop. Take a look at the built in CAN examples in LabVIEW for an idea of how the code should be structured. Look in the Example Finder under Hardware Input and Output»CAN»NI-CAN»Frame API»Basic»CAN Transmit - periodic.vi.
With the above example, to change the arbitration ID, you will need to close the connection, change the ID and then run through the configuration again.
I hope this helps!
Tanya Visser
(7,100 Views)
