Programmatically retrieving the DeviceNet "Connection" object in LabVIEW (like SimpleWho can)
I can already get all of the "Identity" object attributes, but how does one get the "Connection" object attributes?
Specifically, I would like to get the poll input/output lengths so I can set up an I/O connection.  It looks like SimpleWho can get this info without actually opening the connection.  Is this possible from within LabVIEW?
(5,170 Views)
The new driver version 1.5 brings some new examples and one of them creates  a device list. Perhaps this is something helps you with your problem?
DirkW
(5,135 Views)
This VI accesses the "Identity" object, which I can already do (see above).
Really what I'm trying to do is get the input/output lengths for poll mode which are (I think) stored on the devices themselves.  It looks like SimpleWho and the new "Configurator" in NI-DNET 1.5 can do this, but I haven't been able to get this as of yet.
(5,102 Views)
I am not sure how does SimpleWho retrieves connection object information,but you can try this VI.
Make sure you only have explicit connection established and use this VI to retrieve Connection object I/O size and use it to polled I/O connection.
Good Luck 😉
(5,096 Views)
lvABC, you are the man!
This VI was just what I needed - it helped me to understand the "Allocate Master Slave" and "Release Master Slave" services of the DeviceNet object.
Now I can do just what I needed.  Thanks!
(5,085 Views)
