Question regarding ECUMC 18.5 new timing feature
hello
I have question regarding ECUMC 18.5 new timing feaature.
I found ECUMC 18.5 support new timing source feature for synchronization below.
【Added support for Selectable Timing Source for XCP​. This allows synchronization of time with either the ECU, CAN (DAQ), or host.】
http://download.ni.com/support/softlib//embedded%20networks/CAN/addon/ECUMC/18.5/Runtime/readme.htm
I'm really appreciated to help me out how to access this function.
I could not find related document on ECUMC help.
thanks regard.
(2,848 Views)
Hello Iniesta_Luján,
It is documented in the ECUMC help. You can find it in the Get Property sections of the API:
  • If you are using LabVIEW: MC Get Property: DAQ: XCP: Timing Source
  • If you are using C: mcGetProperty: mcPropDAQ_TimingSource
Kind Regards,
Tim
(2,840 Views)
Hello Tim
thanks very much for your reply.
it's my mistake, I found it on help.
thanks for your help.
(2,821 Views)
