 beavercreek
			beavercreek
			03-28-2007 11:14 AM
03-29-2007 03:04 PM
04-02-2007 01:35 PM
04-05-2007 02:22 PM
04-05-2007 03:25 PM
04-06-2007 08:54 AM - edited 04-06-2007 08:54 AM
Message Edited by DirkW on 04-06-2007 08:55 AM
04-06-2007 11:35 AM
04-09-2007 08:42 AM
I guess your complain is the PWM Command channel, which is a steady line in graph 2? It seems this channel is acquiring allways values above 6000? Well i could not reproduce this here with NI-CAN 2.4. Did you check the values in parallel with a second device?
Perhaps you could try LV 7.1 and NI-CAN 2.4?
DirkW
04-09-2007 10:28 AM
Yes, should look identical to graph 1 (ie following the other signal, but at larger magnitude)
To me it seems to have grabbed one sample, (the first one) and never reported any of the new values. I can kind of prove this by running the vi multiple times and the line will move position on the screen.
I have verified the messages are changing with secondary CAN bus hardware/software. (plus if i reduce the # of samples it will work again)
My company is moving to LV8.2 so that should allow me to move beyond the LV7.0 NI-CAN 2.3.2 limitation. Thanks for trying Dirk!
