Read and decode .dbc and .a2l files using Labview VIs?
I am using Kvaser CAN interfaces and Labview 2012. Since those are not supported by MAX, I would like to know if there are some Labview Vis available (in NI-CAN?) that perform the task of reading and decoding .dbc and .a2l files.
Christophe
(7,931 Views)
decoding of a CAN DBC files is offered by the XNET API, even to convert a raw frame into a physical signal can be done be XNET Conversion API.
so I recommend to install NI-XNET and check the example finder,
Decoding of A2L Files can be done by using the NI ECU Measurement and Calibration Toolkit.
refer to
https://www.ni.com/en-us/shop/product/ecu-measurement-and-calibration-toolkit.html
(7,930 Views)
That is good starting point for further investigations. Thanks.
(7,796 Views)
(7,795 Views)
