Read consecutive frames (NI CAN)
Hai
      Give me an idea how to read consecutive frames.
after sending a command to the ECU(Flow control), ECU will transmit 4 consecutive frame at 4ms time interval, how to read all the 4 consecutive frames.
pls can anybody help me on this
thanks
sk
(4,974 Views)
Hi developer...
It would be helpful if you could specify which Software and hardware are you using to do this. If it is NI Hard- and Software it should be easy.
Write the message to the ECU with a simple write net and then use a while loop with wait for state to wait for this 4 message. The wait will block the thread until all four message arrive and you can read them immediately using a read mult net after the wait.
DirkW
(4,960 Views)
hello DirkW
thanks for ur reply
           I am using NI PCMCIA Series II CAN card and LabVIEW 7.1 software
i tried but some frames are missing,
i attached my program, please give me an idea how to do it.
thanks
sk
(4,956 Views)
hai
     Is it possible to monitor the CAN data transmit/receive , time & id  etc., using two NI PCMCIA CAN card. in my Notebook
thanks
sasi
(4,953 Views)
hello
i tried, but some frames are missing,
i attached my program, the sequence where i colored green is where i am reading frames.
thanks
sk
(4,945 Views)
hello
thanks
sk
(4,940 Views)
as posted in one of your similar threads here is an example for reading 4 or more consecutive frames.
And change your programming style to have config and open and close only once outsite your main while loop.
DirkW
(4,930 Views)
