Read rate is very slow when Write and read CAN FD frames at same time
I am trying to write and read CAN FD frames for my ECU by using the USB-8502. The following picture shows my program.
However I get a problem that the speed of read CAN FD from my ECU is very slow and actually my ECU will send out message in 100ms per frame. Then I use CANoe(vector) to read the CAN FD message at the same time, CANoe can get all the message from my ECU and at a correct rate. So I can get the result that write CAN FD is successful of my program.
Could you help me to find the problem in my program.
And I also have another question: When I use CANoe write and read CAN FD message, and also use NI bus monitor to read the message from CAN bus which will stop the CANoe project. I don't know why.
(6,512 Views)
Well, you have a 100ms sleep in each loop. That will limit the frequency of writing a can frame to one per 100ms.
(6,489 Views)
Thank you for your reply.
However, I modified the loop time to 20ms, the speed of read message is still very slow, like one message 3s and very random.
(6,476 Views)
Hey, you problems seems odd but found this information. Perhaps you could double check your sampling points.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7mDSAS&l=en-US
Juan Navarro
(2,897 Views)
