Read the multiplexer signal of a message
Hello everybody,
I'm currently trying to read a message with "mode dependent channels", and I would like to read, as a "real channel", the multiplexer signal of the message.
For example, I have put this table in the CAN Init Start function (Channel API) :
Message.1.channelA
Message.2.channelB
Message.3.channelC   with 1,2,3 corresponding to the mode selector.
When I receive a message, I would like to get the value of the mode selector, i.e. to have a variable with mode selector = 2 when I receive channelB for example.
Is it possible with the Channel API ?
Thanks in advance
(6,217 Views)
No, there is no way to read the multiplexer of a multiplexed message using the channel api. We assumed that would not be needed since you know initially specified which multiplexer to use by configuring the channel list. You could use a second port or device to read the raw message data to see what the multiplexer is.
DirkW
(6,214 Views)
