Reading PDOs from buffer with multiple NODEs?
I am running 5 nodes, and have each node simultaneously move a motor.  When all motors complete, my CAN receive buffer should have 5 PDOs each indicating a move completion.  When I read a PDO, it is removed from the CAN buffer, correct?
Now, If Node 1 is set up to begin reading PDOs (waiting for the right PDO), will it read all PDOs or only the ones with the correct COB-ID?  I would like to be certain that anytime a PDO is read with the CANOpen Library, it does not read (and remove from the buffer) PDOs meant for other nodes.  I assume since I create a PDO object specifing a Node ID, that this PDO-Read will only pull PDOs with matching NODE ID from the central can receive buffer.
(5,363 Views)
Yes the CANopen driver creates a single object for your TxPDO, thus every Tx PDO uses his own buffer.
DirkW
(5,355 Views)
