Reset CAN Network Object using NI-XNET
This post
http://forums.ni.com/t5/Automotive-and-Embedded-Networks/How-can-I-reset-a-NI-CAN-network-object-wit...
mentions that there is a better way to reset an NI CAN network object using the NI-XNET API. Can someone please share how to do this using XNET? What's the equivalent of ncReset in XNET?
Thanks.
(8,149 Views)
Sima,
The closest thing in XNET is the XNET clear.vi, described in the XNET Hardware and Software Manual on page 4-419.
The use case for the VI is still pretty limited, as LabVIEW will take care of most clean up itself.
Hope this helps,
Jen W
(8,140 Views)
Still, is there a way to do a generic reset of the card - not the clear VI, which is specific to a task? I already have a bunch of code written in the old CAN channel & frame APIs and want to implement a reset with the XNET API.
(8,087 Views)
Sima,
Unfortunately, XNET does not have an implementation of a board reset.  There certainly are cases in which one would be useful, so you can always fill out a Product Suggestion.  If you do decide to do that, which I definitely encourage you to do, be sure to include as many specifics about the scenario as you can to show that you really do need a board reset and not just an XNET clear.  Hopefully this feature will get implemented in the future with this feedback, and I'm sorry there isn't a better solution right now.
Best,
Jen W
(8,082 Views)
Jen, thanks for letting me know.
(8,080 Views)
