Running Labview ADCS examples using PXIe-8510
I am trying to run the ADCS example on CAN1 and CAN2 of the PXIe-8510, however I am getting a no response error.  Am I missing something?
1.  I physically connect CAN1 to CAN2
2.  I Start the Diagnostics Demo .vi
3.  I start the UDS Get DTC.vi (also happens to other examples)
4.  No response error (See attachment)
(3,187 Views)
The settings on the VIs look correct.
Are you using properly terminated cables? You will either need to properly terminate your network to 60 Ohms total or modify the examples to turn on software selectable termination.
Jeff L
(3,159 Views)
Thanks Jeff.
The example worked after adding terminating resistors.
(3,153 Views)
