Show in front panel CAN status from cDAQ front LEDs
Hi to all!!
I want to ask if is possible to show in Front Panel of a VI the status LED phisical on the front of the NI-9862.
(2,641 Views)
The XNET API does not have a property to directly read the current state of the LEDs. That might be a nice feature though so I will add it to our list for consideration.
The XNET API does offer properties and function calls that provide you with most of the same information conveyed by the LEDs. For example, you can call the XNET Read(Comm State).vi to determine the communications state.
Jeff L
(2,630 Views)
