05-08-2010 02:52 AM
As part of a University project it is my task to try and access the CAN bus of an inverter.
The inverter is being programmed at the moment to operate as required.
I have a USB-8473s which will be used to acquire data from the inverter when it is programmed.
I was wondering if there is a way that I may be able to simulate a CAN signal (possibly by an NI hardware device) and input that into the USB-8473s in such a way that I can create some Labview VIs and test them.
05-10-2010 10:17 AM
Hello svall88,
You can use the USB-8473 to write to the CAN bus and read from the CAN bus. You could always get a second USB-8473 to "simulate" the inverter.
Let me know if that helps.
05-10-2010 08:56 PM
Thanks for the suggestion, I have thaught about it and I think this will be the way I will go.
This will allow me to understand how CAN communicates and how to use the signals.
05-11-2010 03:19 AM
05-11-2010 07:12 AM
