Starting CAN application
I need a sample code to start an application with NI-CAN/LS2 board.
I need to send periodically (100ms) a CAN frame and I need to read preiodically (100ms) too another CAN frame.
I'm develloping in VB, and it's my first time with this board. Can someone help me to start my application?
Thanks.
(3,535 Views)
Basically, there are two locations where you can get started. The first one and once you have installed NI-CAN driver, you can see the examples included with it ( ..Pogram Files/National Instruments/NI-CAN/MS Visual Basic...). The second one would be to go to the Example Code Library on the web and look for them.
regards
crisr
(3,535 Views)
