Suddenly "Memory Resource Conflict" was happened, How can I solve it?
I used PCMCIA-CAN card as usual, but suddenly the card stop.
And I tried self-test on PCMCIA0CAN Measurement & Automation Explorer, but the self-test failed and memory resource conflict was reported.
Then I checked conflict on device manager of Windows XP, but no conflict for memory and also interrupt.
There is a website which explain how to solve this kinds of error, and I tried the solution explained here. But I have still the problem.
[link removed]
Also, PCMCIA0CAN Measurement & Automation Explorer shows hardware series of the card is 1, but I am using PCMCIA-CAN series2.
Could you please let me know how to solve the problem?
Early answer will be highly appreciated.
Thank you for your help in advance.
いつもどおりPCMCIA-CAN のカードをつかっていたら、急にカードが動かなくなりました。
PCMCIA0CAN Measurement & Automation ExplorerでSelfTestをしたのですが、失敗しmemory resource conflictと表示されました。
そこで、WindowsXPのデバイスマネージャでConflictをチェックしたのですが、メモリーも割り込みも問題ありませんでした。
上記のWebにこの種の問題の解決方法が載っていたので、試してみたのですがだめです。
私が使っているカードはPCMCIA-CANのシリーズ2なのですが、PCMCIA0CAN Measurement & Automation ExplorerのHardwareSeriesは1になっています。
どうやって問題を解決したらよいのかを教えてください。
早めの対応をお願いします。
(5,193 Views)
Truy the following :
1. remove the board from your PCMCIA carrier. ands close all NI software. (MAX, LabVIEW, CVI...)
2. uninstall the NI-CAN driver and reboot your machine.
3. Install the newest NI-CAN driver 2.4 from here  and reboot again.
4. insert your board again and check in MAX for the board.
Please post your results to this thread.
DirkW
(5,176 Views)
Dear DirkW,
Thank you for your advice.
The problem was resolved and now everything is working.
By the way, Is this a problem of occurring frequently?
It is troublesome if the problem often occurs. For example, weekly or monthly.
Miyako
(5,164 Views)
Hopefully this was an problem of the underlaying service software for the PCMCIA hardware. We changed to a new version for this software with NI CAN 2.4 and you should not face this problem anymore.
DirkW
(5,153 Views)
Thank you for you reply. I feel relieved.
Miyako
(5,146 Views)
